Daisy 880
Tell us about your experiences and exchange exaggerations of the truth.
Daisy 880
Postby tx river rat » Sat Apr 11, 2009 12:14 pm
I bought one of these last year ,a light pumper for squirrels ,it came with a scope.
This thing was driving me crazy ,would not hold a decent group. I finally pulled the scope off went back to open sights and the little gun settled into a 1/4 inch group at 15 yards. Even with my geezer eyes.
Beats me why they will take a good shooting gun go to plastic receiver then dove tail it ,the dang plastic was giving in the dove tail.
I think I am going to get on my lathe and build a peep for it ,might clear up my sight picture.
There ain't no perfect tent,wood,boat,hatch,sleeping bag or women
Quote from a Texas Redneck
User avatar
Re: Daisy 880
Postby gbinga » Sat Apr 11, 2009 12:27 pm
Williams makes a peep sight that will fit a dovetailed receiver. I use peep sights on both of my air rifles. Too cheap for a scope, not satisfied with open iron sights.
GBinGA
http://www.williamsgunsight.com/gunsights/gunsightsdefault.htm
*Faster Horses, younger women, older whiskey, more money - Tom T. Hall
*Too much ain't enough - Billy Joe Shavers
*Anything that's worth cutting down a tree for is worth doing right - Guy Clark
Re: Daisy 880
Postby tx river rat » Sat Apr 11, 2009 12:37 pm
Thats the problem the reciever is plastic,I am going to mount this on the barrel.
User avatar
Re: Daisy 880
Postby jdupre' » Sat Apr 11, 2009 1:51 pm
Ron, I have an 880 that's about 20 years old and it has a metal receiver- just old pot metal. I recently put one of those $6.95 WalMart scopes on it and it helps a lot with the sight picture. The gun is a shooter. Dinging cans out to 70 yards. Fun stuff. At the suggestion of one of the guys on the air gun forum, I chucked a pointed carbide bit in my drill and EASED the crown of the muzzle a little. Seemed to have helped.
I took it out of the closet and dusted it off after shooting Piper's neat little Crossman pistol with a shoulder stock. Pretty accurate little gun. I'd like to see what it would do with a scope on it.
Hey, anybody can make a silk purse out of..............SILK
ALWAYS question authority.
User avatar
Re: Daisy 880
Postby tx river rat » Sat Apr 11, 2009 2:34 pm
JD
I wish this one had a metal receiver the plastic gives to much,but she is a shooter
User avatar
Re: Daisy 880
Postby jdupre' » Sat Apr 11, 2009 2:59 pm
tx river rat wrote:JD
That's pretty dang good accuracy for an inexpensive little gun from WalMart. That will give some of those high-dollar guns a run for their money.
How's the trigger on yours? Mine is probably about 10-12 lbs. My best shots come when I ease the trigger back with about 80% of the pull and touch off that last little bit when on target. Can't do it all the time, but it works.
User avatar
Re: Daisy 880
Postby tx river rat » Sat Apr 11, 2009 5:04 pm
Your right about the trigger it is horrible,but if you can shoot the ones with a bad trigger then shooting one with a good trigger is a snap.
User avatar
Re: Daisy 880
Postby bearridge » Sat Apr 11, 2009 6:32 pm
tx river rat wrote:I finally pulled the scope off went back to open sights and the little gun settled into a 1/4 inch group at 15 yards.
3 'er 5 shot groups? I caint shoot open sites worth a dang. With the Slavia 631 (see pichurs at piper's geezer gatherin'), I managed a few half inch groups at 11 yards, but out ta 20 my five shot groups wuz bout 1.5". I wish I had a kevlar bird feeder.
Convictions are more dangerous enemies of truth than lies.  Friedrich Nietzsche
Re: Daisy 880
Postby gbinga » Sat Apr 11, 2009 9:54 pm
Joey - which air gun forum are you using? I'm lurking in a couple, but haven't picked one to infest yet.
I've seen some sights where they show you how to clean up the triggers on Crossmans, but have not run across info on Daisys.
Re: Daisy 880
Postby bearridge » Sat Apr 11, 2009 10:00 pm
http://www.airgunforum.org/ There iz others, but this iz the big daddy, dip dog, funky monkey of airgun forums. Tell 'em I sez so.
Re: Daisy 880
Postby jdupre' » Sat Apr 11, 2009 10:35 pm
Yep, that's the one.
User avatar
Re: Daisy 880
Postby Tom @ Buzzard Bluff » Wed Apr 15, 2009 9:44 am
Ron,
Much the same problem prevails with the earlier metal receiver as well. The real problem is that the interface of receiver and barrel isn't rigid. On guns with a solid barrel that can be overcame by mounting a pistol scope forward on the barrel itself but the 880 series has a 'soda straw' barrel inside a rolled sheet metal outer shell.
Your idea about making a better sight and mounting it forward of the receiver is about as good as it's gonna get without a complete redesign of the receiver/barrel lash-up and a lot of machine work to adapt a proper barrel.
All that said I have had a few pass thru my hands that were tackdrivers. But they were ALL the earlier cast receiver model with the metal pump lever, If you could find one of them and stuff the 'innards' of your new model into the older gun using a bit of epoxy in strategic areas you might come up with a 'good'un'. You could also clean up the trigger while it was in pieces. And you'll curse me for suggesting it when springs and small parts explode in every direction when you split the receivers. :D
Religion, morality and knowledge being necessary to government and the happiness of mankind, schools and the means of education shall be forever encouraged,---Congress, Northwest Ordinance of 1787
Tom @ Buzzard Bluff
Re: Daisy 880
Postby jdupre' » Wed Apr 15, 2009 11:02 pm
Tom, you mean all those pieces that came out have to ALL go back in? :?
:mrgreen: :mrgreen:
I must have a transitional model. I have the cast receiver halves but have the plastic pump lever.
User avatar
Re: Daisy 880
Postby Tom @ Buzzard Bluff » Thu Apr 16, 2009 12:23 am
[quote="jdupre'"]
<Tom, you mean all those pieces that came out have to ALL go back in?>
Well----most of 'em. :D
<I must have a transitional model. I have the cast receiver halves but have the plastic pump lever.>
You do indeed!
FWIW to the 880 owners out there in 'Airgun Land' ( :wink: ) there's a 'quick and dirty' hop-up for that series. Just keep in mind that if you do it and destroy your gun----well---you're on your own. :D
Open the pump lever up and take a gander inside the pump tube. You will see a link section that holds the piston and O-ring at one end and is pivoted to the rest of the pump linkage on the other. That link contains a rubber 'biscuit' that is designed to prevent overcharging no matter how many times it is pumped. The 'quick fix' is to replace that rubber biscuit with a stack of flat washers of equivalent thickness.This can only be done with the earlier models with the metal pump lever because you WILL break the plastic pump lever if your gun is so equipped! The plastic lever was designed to thwart exactly the modification described! It's the 'insurance' link in the chain.
I have in my collection the original 'Velocity Standard' gun of the 880 series from the Daisy R & D department. In place of the rubber biscuit it has an ingenious adjustable piston that can be adjusted to provide any level of pump pressure to the valve. Which goes a long way to explain just how they were able to achieve the advertised velocity figures for the gun! :D
Tom @ Buzzard Bluff
Re: Daisy 880 (MODIFYING THE TRIGGER)
Postby AirgunAddict » Sat Sep 26, 2009 4:05 am
Just a note that to those who are interested, modifying the Daisy 880 trigger is not only doable, it's very easy.
Granted, take it into perspective that it's a $35 gun, so how much effort do you want to put into mods? Well, that's up to you. I enjoy shooting the 880 and other multi-pump Daisys when I'm feeling lazy and don't want to bring out the bigger boys and didn't like the triggers on mine, so here's what I did to get them from the factory issue 7-8.5 lbs down to about a much more reasonable 2-3 lbs.
This is a very easy way to modify the 880's trigger without worrying about a lot of tools or a complex process. (You'll need a regular and Phillips screwdriver and wire cutters)
1. Make sure the gun is not loaded, discharge any air for safety reasons.
2. Remove the receiver screws, the safety trigger guard and the the loading bolt (standard dis-assembly noted elsewhere on this forum)
3. Remove the lower push pin that closest to the trigger being careful to ensure that the spring behind the trigger doesn't pop out
4. Remove trigger and then the main spring behind the rear of the trigger, this accounts for about 70% of the trigger pull on the 880
5. This part varies a bit, so try and use small increments to get the feel you want. Basically cut the spring 1, 2 or 3 "curls" down to reduce it's length. I have found that crimping the cut end a little helps keep it in place. This is the end I re-install on the male-nipple on the trigger unit that we removed in step 4.
6. Re-install the trigger with the lower push pin, making sure the spring is re-seated correctly.
7. This step is optional and if done too much, will make the gun unsafe or mis-fire, so proceed at your own risk. Take the regular screw driver and GENTLY depress the discharge blade several time to bend it slightly down near the location closest to the where it moves into the mechanism toward the barrel of the gun. (NOTE: The discharge blade is the light metal blade that the trigger unit moves back and forth as the gun is cocked/fired. It is easily seen below the loading port where the pellets and BBs are chambered.)
That's all there is to it.
It should be fairly straight forward; but can post pics of one of my modified rifles if needed. I have a couple that now have a 2.2 and 2.5 pound triggers which makes shooting much more reasonable.
Shoot straight and enjoy the fun of this little 25 yard plinker!
-Addict
AirgunAddict
Next
Return to Shooting , Hunting , Air Rifles , Bows & Arrows
Who is online
cron
