sould have stayed at home
Talk about Canoeing and Stuff
Moderators: hairymick01, oldyaker, oldsparkey, JEM, tx river rat
Postby makenmend » Sat Jul 09, 2011 11:01 pm
went out with the HOW folks on the San Marcus,halfway into the trip having past through a fastish run, back paddling to see that the followers were coming through saftly my wooden paddle shaft gives up
should have stayed home (3)_resize.JPG (59.39 KiB) Viewed 527 times
Then to add insult to injury going through a fast bend (with half a paddle) I collide with a downed tree and hole my boat just below the waterline
should have stayed home (6)_resize.JPG (76.89 KiB) Viewed 527 times
should have stayed home (8)_resize.JPG (91.91 KiB) Viewed 527 times
Made it to the take out sitting to the good side with the gunnel just clear of the water and the damaged area barely out of the water bailing with a sponge as I went, thanks to other volenteers I made it back. Now its back into the workshop for me
makenmend
Re: sould have stayed at home
Postby makenmend » Sat Jul 09, 2011 11:10 pm
paddle with dowel insert and goopied
should have stayed home (23)_resize.JPG (59.68 KiB) Viewed 525 times
wood to compressed and delaminated to sand and reglass, so removed damaged section.
should have stayed home (7)_resize.JPG (109.96 KiB) Viewed 525 times
should have stayed home (15)_resize.JPG (93.64 KiB) Viewed 525 times
dry fit patch to check fit.
makenmend
Postby makenmend » Sat Jul 09, 2011 11:18 pm
now goopied in place,
should have stayed home (27)_resize.JPG (108.68 KiB) Viewed 525 times
Well proly going over the top a little,she now has an additional 6 oz coat inside plus 2 layers 3 oz outside,not just for peace of mind but to beef up the sides in antisipation of extra side loads generated by the outriggers/sail assembly.(Still a work in progress)
Mast,boom & paddle shaft (17)_resize.JPG (106.28 KiB) Viewed 525 times
So some filling sanding and varnish and she's good to go again
Mast,boom & paddle shaft (19)_resize.JPG (98.58 KiB) Viewed 525 times
makenmend
Postby Kayak Jack » Sun Jul 10, 2011 8:04 am
My wife used to say, "A well scratched boat is a well loved boat." Nice repair jobs.
Postby jdupre' » Sun Jul 10, 2011 12:55 pm
Nope, you shouldn't have stayed home. Months and years after the memory of the patch job is forgotten, you will have one more story to tell your friends and relatives. "Did I ever tell you about the time I went through those raging rapids with a broken paddle and a half floating boat?" Yep, it will become one of many stories you can look back on with pride and wow your audience.
Hey, anybody can make a silk purse out of..............SILK
ALWAYS question authority.
User avatar
Postby mike » Sun Jul 10, 2011 2:14 pm
jdupre' wrote:Nope, you shouldn't have stayed home. Months and years after the memory of the patch job is forgotten, you will have one more story to tell your friends and relatives. "Did I ever tell you about the time I went through those raging rapids with a broken paddle and a half floating boat?" Yep, it will become one of many stories you can look back on with pride and wow your audience.
Yeah, and don't forget about the bear that was chasing you! This has all the makings for an epic tale, you just need to let it grow a little with each telling. :roll:
MIke
Visit us at Cracker Barrel Philosophers . com
First registered as "Bilgerat" on May 10, 2006.
Postby Kayak Jack » Sun Jul 10, 2011 2:54 pm
And, Mike, that bear was running to escape the Apaches coming along right behind it. :wink:
Postby loafer » Sun Jul 10, 2011 11:13 pm
I knew there was a reason I liked following this forum :lol:
loafer
Return to Canoeing
Who is online
