Brass vs Bronze fittings | SouthernPaddler.com
DJR
24
Melbourne, Victoria, Australia
Hi,
I'm considering making my own rudder components for my current kayak builds - a Chesapeake 17 and a racing TK1.
Has anyone used sheet/bar stock of brass or bronze to make fittings for their craft? I understand brass will corrode, so bronze is preferrable (at least in salt water), but I'm unsure about the working properties, and whether a rudder-sized sheet of bronze (say 12" x 3" x .20") would be stiff enough to use.
Although I'm sure the old mahogany race boats often used brass rudders & fittings...
Appreciative of any answers...
Thanks,
Darren
Mate,
Both can be brittle and the expense of it just can't be justified IMHO. (unless you are thinking od building a show boat)
For all practical purposes, 304 or 316 grade Stainless or even aluminium would be a better proposition and much cheaper.
I would build the rudder blade from 3mm aluminium and the mounting/pivot assemblies out of stainless.
DJR
24
Thanks Mick & et al,
Appreciate the comments - looks like aluminium or s/steel is the way to go...I just thought brass would look nice, hadn't considered the weight being that much different.
I guess on a 30' mahogany raceboat with a V-12 pushing it, the weight of a small brass rudder is a lot less noticeable than on a 17' paddle-powered kayak! :)
Regards,
Darren
