curved stem | SouthernPaddler.com
curved stem
Been some interest in how to make curved stems for your pirogue so I thought I'd give a rough outline.
Lots of pictures so I'll do it in several posts
There's no right or wrong way to make a curved stem as long as you end up with the desired result
Here's the way friend Keith and I do it
start with a panel that's the side of your pirogue, here's the end of a piece of plywood that's 12" wide
so far so good, next draw in your rake or cut back, on a pirogue this is typically 6 to 12", I'll use 9" - draw that line
there's hundreds of ways to get a curve, what I did was to move up the cut back line about a third of the way and draw a point 1" out
you have three points, take a flexible batten and draw the curve
if you don't like the curve, now's the time to redraw because the next step is to cut the end of the panel
and cut the other side to match
with the sides matched, next transfer the curve to the stem, I'm using a scrap piece of 2 X 4, some folks like to use a larger piece - i'll explain this later
now cut the stem (2 X 4) to match the curve in the sides
flip the stem on its backside and draw a line down the center
we build on jigs so the next step is to determine the angle where the sides come together, I've used an already built boat for the demo
the angle on this boat came out to 50 degrees, so set the bandsaw for 25 degrees
keeping the back of the stem on the saw table, cut to the center line
flip the stem around and cut the other side
and you now have a curved stem piece that matches your sides
drop it in place and fasten
notice that the backside of the stem stands proud from the sides, if you use a wider board or trim the stem before inserting, you can reduce or eliminate the part that stands proud and have a stem whose sides are flush with the sides of the boat
however you do it, you end up with a curved stem in your boat
I'll add this disclaimer that this was done with some scrap wood and if i was using real wood and building a real boat, i would plane or sand the bandsaw cuts to get a better fit for the sides and i recommend that you do likewise
don't know what you're building without stems or what materials you're using, but
neither planks nor 1/4" marine plywood likes to easily bend the way we bend them
for us, the stem pieces hold the sides together at the ends and also provide for sealing against water intrusion
i can't imagine touching the ends of plywood or planks together and getting a water tight seal
but then maybe you're making your seams and joints water tight with fiberglass and epoxy
not sure i understand,
the inside angle is the same as the outside angle, you could always cut away the back side of the stem if you don't like the part that stands proud
reckon you're right about stitch and glue not needing stems, never built a stitch and glue
mosportsmen
299
Kirksville MO
mosportsmen.com
Stems just caused me more of a conundrum when I built my second pirogue (a compilation of several designs). Couldn't figure out or cut a nice angle on the stems with the tools I have available.
Tying the ends together and filling it with fillet epoxy is lots easier. I forced quite a nice compound curve on my TV with zip ties and spacers.
I do like your curved bow and or stern though, looks good, probably could make the bow a little less susceptible to damage when coming in for a beaching or graveling as we do here in Missouri.
Makes sense, don't know why I didn't think of that.
Tom
The standard way of fasting the stems on a stitch and glue boat is to tie the ends together with copper wire or the quick ties.
The bow of the Sasquatch 14 x 30 I made.
Then epoxy them to hold them in shape and create a leak proof area. When that is done the ends are poured with epoxy to stiffen them. Usually a dam is made about an inch back from the junction and that void is filled with epoxy. Or the boat can be stood on end and the epoxy pored in there and left to cure. The epoxy takes the place of the wood stems that you use.
Personally... I like to dam the area and then use left over epoxy to fill the void as I use epoxy on the rest of the boat. It cuts down on the amount of epoxy that would be wasted.
<SNIP> Personally... I like to dam the area and then use left over epoxy to fill the void as I use epoxy on the rest of the boat. It cuts down on the amount of epoxy that would be wasted.
I do that too. And, on kayaks that do not employ bulkheads for separate cargo areas, and hatches to gain access, I'd stick a loop of parachute cord into the top of the end pour. I'd tie a small pulley to that, and rig a circular rope (ends tied together) through it and back to the cockpit. I tie on the first piece of cargo that goes into the hatch, and run it up to the end. For unloading, I pull on the rope and upset the load that is stuffed up under the deck (fore and aft decks both) and unload the gear.
captaindoug
142
Tampa Bay, Florida
I for one appreciate the tutorial, and like the man said, he doesn't build stitch and glue boats, so how ya'll do it with that kind of construction doesn't really apply to this post. Thank you for the lesson Seedtick, and for you folks that don't want to do it that way,..don't :lol:
mosportsmen
299
Kirksville MO
mosportsmen.com
Well I guess I am put in my place. Reviewing my posts I guess i did fail to express my appreciation for Seedtick's work on this post.
Don't mean to be a detractor, just a devils advocate, I suppose.
The use of the band saw and showing how to draw it out are great tips for making stems.........if you want stems.
Thanks Seedtick!
Tom
Well, Mo, I don't think anyone is trying to be critical of you. Each of us do things differently.
The only power tools I have are a 3/8" drill and a sander (not counting my electric shop lights). I saw with a Japanese hand saw that cuts on the pull. Not as quick (or accurate) as a band saw, so if I cut out a stem piece from a larger chunk, I'd still have some planing and sanding yet to do. If my tools were much more primitive in design, I suppose I'd be using a chunk of flint or a clam shell. :wink:
