Normally I don’t have too much of a problem in wetting out fibreglass cloth. I just pour epoxy onto the cloth and spread it out with a plastic spreader. I then squeegee off the excess. The problem I have had is where I lay cloth over a wetted out cloth. For example when glassing around the bow I finish the cloth on one side and wrap the cloth on the other side around the bow and overlap the first side an inch or two. The problem I have is that where the overlap exists it tends to turn out a sort of milky white. This is probably caused by minute bubbles in the epoxy. This is an annoying little problem and I was wondering if anyone has any ideas on how to overcome it or what I am doing wrong.
