There was a thread in the general section -
http://www.neilbank.com/phpBB2/viewtopic.php?t=6019
- that linked to a video where they were making wooden kayaks in a factory, and instead of scarf joints or butt splices they were using finger joints. There was some discussion about that being an interesting way of joining two pieces of plywood. I think it was Mick from Australia who opined that trying to do that with hand tools was more trouble than it was worth - impossible or impractical to get the kind of precision that you would need. I tend to agree with Mick about that.
But...
What if you knew someone with a CNC router, and you got them to make a pair of templates for you out of, say, phenolic sheet, or perhaps even aluminum. Then you use the templates as a router guide, with a pattern bit. The kind of bit with a bearing above the cutter. The bearing rides the pattern, and the cutter cuts the stock.
Once you had the tool (the pair of patterns, that is) you could finger joint plywood again and again, without the hassle of trying to make an actual scarf joint.
I know of a business with a CNC router near where I live. They do specialty work on a job-by-job basis. A lot of work for sign companies, some for countertops, just about anything that a customer could bring in a CAD drawing on. They used to cut out a lot of sign material from 1/4" aluminum sheet, and could cut just about anything else in the way of sheet goods.
I wonder if this would be a practical idea?
But...
