Friend Ron,
I dont know how close this iz ta ya, but it sounds like the High Sheriff aint the only one who kin pull up a hoodoochie.  I copied these posts by a fella on anuther forum.
well, its been a while since we had any water around here ( texas panhandle) and man did it come last night, 10 inches in spots. SOO, I decide it would be a good choice to take out the 17' tripper, solo. Normally you can walk Wolf creek, and keep your cuffs dry, however today it was ripping. lots of strainers, trees, debris floating along.
so, I avoid a big strainer a try to thread the needle between a couple of large trees, and it didn't work. I knew the barge would handle a little sloppy, but figured it would be doable. NOPE. It wrapped, completly, ends of boat touching. once i knew it was over, I bailed, and grabbed the end of the boat hopeing my body would act like a sea anchor, and do some good. It didn't. I was able to get up on the boat, and pounce around, and nothing. after thinking about what a fine job i had done, i decided for a SW entry, into a hairy fairy for the nearest eddy. self rescue solid, but the boat will be there a while. Unfortunatly, my chaco 's are clipped into it.
o well, maybe my chaco tan will fill in now.
Im safe, no injuries, but the boat...well..........she's done for sure.
Im not kidding at all. Highway 83 runs north/ south here, its completely closed due to a HIGHWAY bridge being completly washed out. REMOVED a highway bridge
Im anxious to where the boat ends up in relation to actual (normal) water levels. I will for sure get some pics, and will put em on webshots or something, thats about the only way i know how to add pics to the web.
a guy down stream had (2) 500 gallon butan tanks "removed" from his house. completly flooded his house/shop/barns.....etc.
crazy stuff. there was a major flood here in 96' that was the biggest one the oldtimers had seen in their lifetime, this one was bigger. the last flood didn't touch the guys house/barns/shop...
a friend has a 10 inch rain gauge, and it was overflowing.
Randy, the hull is Royalex, but it was old and brittle. To much sun damage, I figured i would be fine, but in avoiding that big strainer, I had no options other than to thread the needle, and man, I ALMOST had it
UPDATE: I just went back with a disposable camera, My battery is shot in my digi. I went to the location that I wrapped, and looked at nothing. After the wrap, I tied it to the tree is was wrapped on. I went back, and the tree, and the boat were gone! I was upset to say the least. I drove out of the area I was in, crossed a bridge, looked down stream, and there the tree, and the boat were. Now, im no expert but im thinking my initial thought of it being "done" were correct. the boat is completly broken in half, in two pieces. I don't know if the shots i took will do any justice, but the only thing holding the boat in its position is a cam strap linking the two halfs together. Granted, one end is tied on, I don't wanna loose my gear .It was all clipped/tied in.
It will need to stay there another couple of days, for the water to drop, then i will take some more pics, and get them posted.
I think I have a new piece of yard art, Im thinking about painting "canoe instuction here" on the side
