Mersawa | SouthernPaddler.com
Mersawa
I did find this: http://tropix.cirad.fr/asia/mersawa.pdf
and
Indonesian Mersawa Round Logs:
Mersawa is rather plain, but with a slight silver flecked figure and ribbon stripe on quartered surfaces from prominent rays. Generally the grain varies from straight to interlocked and it has a fairly coarse, even texture. It dries very slowly from green, and it is difficult to extract moisture from the centre of thick stock. The interlocked grain and silica content affects machining, causing severe blunting of cutting edges. Mersawa possesses a low bending strength and shock resistance, with medium crushing strength. It has very low stiffness and a poor steam-bending rating. It can be glued and nailed satisfactorily and brought to a good finish. The sapwood is liable to attack by the powder post beetle. The wood is moderately durable and resistant to preservation treatment. It is used for furniture making and general construction, for interior joinery, domestic flooring, vehicle bodies, and in boat building for planking. It is rotary cut for utility plywood, and sliced for decorative veneers.
From my rather uninformed view, the only thing this ply has going for it is the price. Seems like boat wood should do everything this wood won't do. Guess all those Canadian boat builders can't be wrong though. :?
Meranti and Lauan and Luan are all names used by suppliers for the same group of tropical hardwoods.
See: http://www.libertywoods.com/meranti.html and http://www.ipmg.org/id6.html as examples.
These tropical hardwoods are members of the Dipterocarpaceae family. Mersawa is from another member of the same family and sub-family. Laun/Meranti can differ according to just which species of tree is used and I would expect that Mersawa would be pretty similar to some of the Luan/Meranti plywood.
As has been brought up, you aren't likely to be getting marine grade and the grade that you do get might make more difference than the species of wood.
A quote from the second link above:
Whether you call it Lauan, Meranti, or "Mahogany", this product from Indonesia and Malaysia has been the imported plywood standard for many years. ...
As is the case with domestic plywood and lumber, each producer has their own unique "quality stamp" that can be seen in the quality of their production. If your greatest concern is a low price, we have a variety of mills to fit the need. If you need a superior quality product, we also have mills that pride themselves on the products that they make along with their ISO 2000 certifications. You choose the quality that you want.....
