So before anyone jumps down my throat about the advantages of epoxy vs polyester...I know that everyone on here recommends epoxy and love it...etc...etc. However, I have to go with what is readily available to me and stay within my price range.I could order epoxy but I am really considering the polyester. First, I would like to understand the layup process using poly. My understanding is that you can thin the poly out with acetone and it will allow it to soak into the wood,thus increasing its bond strength and strengthen the wood. One question I have is do you allow this to dry/cure out first or do you immediately start laying up the glass? Secondly, do you apply a second coat of poly over the glass once it's cured or can you go straight to paint? The reason I ask all this is because my boat will not stay docked somewhere, it will probably at most see water once a week, and will not be in the water longer than 4-5 hours at a time...and that's pushing it...also it will most definitely be kept indoors when not in the water...this is a fishing boat for personal use not a leisure/house boat or anything of the sort. I doubt very seriously that it will even see water once a week in the summer...it is more likely to see water once every other week. I would really like to learn some more about the layup process using poly before I make a final decision of poly vs epoxy. I know that epoxy bonds to pretty much anything you apply it to but if I can use poly with proper surface prep than I will. I look forward to serious comments and discussion on this so I can make the right decision.
