Boats built from plans are built to a set amount of rocker. Setting the rocker to a specific setting useing the traditional, "cut an arc in the side panels", was hit and miss for me. Gator Boats attach the chines to the floor and then the sides. http://www.gatorboats.com/ My Croc model was built this way. The rocker is set by the design. I proposed the question, "Could the chines be attached to the floor, and then adjust it to the desired rocker? Attach the sides and then cut them flush." http://www.gatorboats.com/forum/viewtop ... highlight= This should allow the builder to get what ever rocker desired.
The answer is YES.
But not easily on the first try. :cry: Is it practicable? Yes, with practice and planning. I wanted 1.5" of rocker at the bow and 1" at the stern. It came out on the money.
Build the frame (chines and floor ribs):
Attach the floor to the frame:
Place over saw horses:
Adjust floor with weight and set the rocker to your measurements. I used a laser level:
I cut the top of the sides to the shape I wanted. This had to be redone after the sides were attached, because the height was wrong.
Attach the sides and cut flush:
It will be some time befor I can try the boat, but I am pleased with the way it turned out.
I am not saying this is a better way to build boats. It was not easy, because it was uncharted territory for me.
The answer is YES.
