Spar varnish | SouthernPaddler.com
Spar varnish
tx river rat said:
How long should epoxy cure before the varnish is applied?
72 hours at the minimum..........I like to go 30 days before varnishing....
Look at it this way ... You use the boat while the epoxy cures all the way , it gets scratched and some water marks on it while using it...... BIG DEAL , You got to use it and see how it handles....... :D
Then after that you lightly sand it ( you would do this no matter if it set in the shop or was used ) to remove any contamination , scratches and other stuff before varnishing.
You have it cleaned , lightly sanded and VARNISHED........ A new boat when varnished after having some fun with it.......
They say it takes the epoxy a total of 30 days to really set up and get to be itself....... Let it grow up before varnishing it. :wink: .
