I finally got started and have been making slow progress so far. My big problem is that the wood I had that I've been wanting to use was a little wormy. I had to cut and cut to find enough that was clean. The ribs and stems are probably about 10% of what I cut. I did pick up nice new wood yesterday though! That should speed things up a bit.
I've been taking a lot of pictures. Most are probably going to be a little boring but I've always intended on documenting a build like this and never have. I'm going to this time. Maybe something I do will help someone else.
Got the ribs cut and ready to glue up.
Ribs are glued up. I decided to go with Gorilla glue over Titebond III. I did some non-scientific tests on both. I glued up some wood with about 2" of glued surface then after it dried I wacked them on my work bench to see how each reacted. On the GG most of what broke was wood, not the glue. On the TB, it was nearly all glue that gave way. That's serious research there!
That's all for now. I'll update this thread as I make more progress.
Greg
Camera focused on the wrong thing but I was trying to show the good lap joint I did.
Another shot of a rib lap joint.
Here are the finished ribs. I had one of the larger ribs slip a little during the gluing process and it was angled out a little too much on one side. I was able to mark it with the correct one and sand it down to make it right. Lost less that 1/8" of width at the top once completed. It should not cause any problems.
If there was ever a situation to use feather boards, it's the stems!
My first mistake. I'm using 5.x mm luan but cut the stems per instructions for 1/4". My cuts seem to be pretty good so I'm going to glue in another piece of wood to adjust for the boo boo.
Greg
