I am making plans to build a pirogue with a grandson afflicted with autism. We usually build Uncle Johns with Grandkids, but we are a little concerned of handling so much fiberglass and epoxy. I’ve come to the conclusion that the stressed skin Herb Lite is the best option for this adventure, especially since the Herb lite is his favorite pirogue.
The herb lites have held up real well except for the 5.2 mm luan bottom with epoxy but no fiberglass. So enough back ground here’s the two questions.
• I’m planning on the bottom using 6” cedar fence boards glued like the normal strips, mostly to keep it simple.ie like a SS&G bottom covered with fiberglass, except the cedar strips about 6” wide by ¼” thick, anybody see a problem with this?
• On previous herblites I used epoxy to glue the frames and aluminum to the frame and will probably will do that on this project. I keep thinking the age old question: would P L premium or some other glue be safer and still work.
Thanks for any thoughts you might share concerning keeping it simple, but reliable. I’m looking forward to this project and will try to share it through a build post when it’s done.
Good Fish’n,
Andy
Good Fish’n,
Andy
