Alternative to Paintbrush? | SouthernPaddler.com
VTFogg
73
Rutland, Vermont
I've only recently joined with this forum, but that's long enough to know there are some creative, resourceful, and frugal members. When applying epoxy to bond the stem/stern to sides (or similar areas) what do you use to apply the it besides a paint brush?
It just seems like a waste to use and then throw away even a cheap brush when doing such a small area.
Thanks for your ideas. - VTFogg
Wimperdink
55
East TN in the Smokies
I cut up the bondo spreaders and use them. It allows you to spread it evenly and when it hardens, just bend until the epoxy seperates from the spreader. Clean and easy. They are cheap and you can cut them to whatever size you like.
dawallace45 said:
If you have to clean a brush with epoxy on it just use white vinegar , it works better than acetone and isn't as bad for you
JEZEeeeeeeeeeeeeee I eat that stuff. Cut up some onions and some cucumbers in a glass container , add a little salt and pepper then put the white vinegar over them and let them sit for a spell in the frig.
