G'day guys,
Been thinking on light, effecient stoves for a while now and remembered a stove my perents used to use when I was a kid and went camping with them. (a very long time ago)
I asked my Dad about it the other day and he told me that he thought that he still had it somewhere and today, he came round with it. :shock:
I remember these things cooked very hot but were also easy to simmer and were the predesessors to the LPG jobbies so popular now.
We call them a "Primus" but I think that has more to do with a brand than what they actually are. They came with a brass body and burn kerosene under pressure. Are very effecient to run and very clean burning. Very low teck. I like that.
First up, about a thimble full of metholated spirit (de-natured alcohol?) is poured into a little cup under the burner and set alight. this pre-heats the kero and helps in creating a clean burn.
As this starts to burn down, a manual pump on the side of the fuel container is lightly pumped a couple of times to get the kero up into the jets just above the metho burner.
and as what remains of the metho burns away, more pressure is pumped into the fuel container and the flame at the burner gets about as hot as LPG.
I think these stoves are superior in many ways to both the Zip and Trangia in that they can burn hotter than either, are about the same size as a trangia and a little bigger than the zip and a lot more stable on the ground than a Zip.
At the very least, this will be a very good to compliment either of them on a camping trip. 8)
