Attaching Bottom to Stem/Stern | SouthernPaddler.com
VTFogg
73
Rutland, Vermont
I rough cut the bottom tonight leaving a couple of inches extra around the entire boat:
http://i155.photobucket.com/albums/s283 ... -07001.jpg
My stem and stern extend below the sides, and I believe this is correct so that the tip of the bottom will but up against the stem. You can see the gap here:
http://i155.photobucket.com/albums/s283 ... -07002.jpg
So, am I correct in that I now need to cut the bottom to its exact length to fit in and but up against the stem and stern? Should I lightly tack it in place to get the length right?
Thanks - VTFogg
Lotsa ways to skin that cat, Foggy. I lightly nail at both ends and tack the bottom onto the frames...and use a bit of Gorilla Glue to hold it all together, press the bottom down with buckets of water, toolboxes, etc for a day. THEN I use the saber saw and cut around, trimming it all to shape.
Piper
stevesteve
111
UK
Hi VTFogg,
I hadn't thought about doing it that way. I cut the stem flush and then stuck the bottom over it. I don't know what is the 'right' way.
