This was built from scrap I had around the house
The frame is built out of 1 1/2 square tubing .072 wall or 14 gauge
with 1/2 water pipe as brace mashed flat on ends
I put a couple loops that I could fasten ropes to and got some screw in bed
pocket adapters and a couple screw clevises
instead of looking for a piece of 2 inch tubing I tacked a rod on the top rear of tube and bottom front to give me more angle
I had to cut and bend the tube up some more so it was level with the bed
burned a hole for the pin and it was ready.
ok for the improvements use 1" pipe for the cross bar instead of square tubing slide on plastic pipe for rollers and then a pool noodle over that
then use bolts thru the pipe instead of welding on pegs.
With ropes attached it carries load really well no bounce
Hope this helps
Hope this helps
