Epoxy, Glue and Adhesive Question | SouthernPaddler.com
wilded
124
Round Rock, Texas
I am building a pirogue and need to know what glue, adhesive or epoxy I should use to put it together that will be compatible with the epoxy I use to fiberglass the boat. I do not want to open and mix the epoxy that is for the fiberglassing until I am ready to do that job. Thanks, ET :roll:
When I use the word "Glue" in describing a build it is always Epoxy that is used. You only mix the epoxy when you are going to use it and you can mix a very small amount when using it as a glue.
I get my epoxy from Raka here in Florida and it is the 2 to 1 mix.
