Pfeffer Neisse (Feffer Ness) for me.
Something my Grandmother (German) would make every Christmas and then My Mother and now myself.
Now days the daughters make a batch every year for the holidays, a family tradition on the holidays for only 4 generations that I know of.
Could be more then just 4 generations since my Grandmother probably got the recipe from her Mother.
PFEFFER NEISSE
3 ¾ cups flour (sifted) 2 ¼ cups sugar 4 eggs
2oz. Candied Lemon peel 1 Teaspoon Nutmeg 1 Tablespoon Cinnamon
1 Teaspoon Cloves 1 Teaspoon Baking Powder.
All Spices are the Ground type and the Lemon Peel is chopped fine ,( when you get it , The Lemon Peel,) cut it again .
Combine the Sugar. Lemon Peel and Spices in a bowl , add eggs and beat or mix it together , add Baking Powder , mix again. Now add the Flour slowly a little at a time and mix until all the flour is in the batter. ( As you add the Flour to the mix it will get increasingly harder to mix , do not give up it will all mix together and you will have a dry dough.( Sometimes you might want to use your hands instead of a spatula.)
Take a little Flour and put this on your work table . This will help you role out the dough which will be cut into pieces and than rolled into balls to be placed on a cookie sheet. #1(You can role the dough out until it is about ¾ inch thick and what ever length that you want , than cut it into ½ inch pieces and role these into balls.#1) The larger the balls of dough the larger the cookie and the best ones are smaller , when cooked they should fit in a spoon just in case you want to drop them into a cup of hot coffee to soften them up, these cookies will get very hard as time goes by so do not make them any larger than the size of a quarter, when cooked. #1( HINT a little flour on your hands will help in this step.)
Pre heat the oven to 325 degrees , place the cookies on a baking pan that has been lightly greased and cook for 12 to 15 minutes than take the cookies and using a spatula place them on a cut brown paper bag to cool.
When the Cookies have cooled they can be put in plastic bag or cookie tins and they will last for years . When Camping , Hiking or Canoeing / Kayaking these cookies are great snack and energy builders and just real good.
********* When measuring out the flour sift it into the measuring cup , if you don't you will have to much flour and the mix will be to dry.
ENJOY
