I'm about at the stage with the larkspur build where I need to be thinking about inwales and outwales/gunnels these days. Actually been thinking on it for a while now and had my local custom cut lumber guy mill me out some 20'X3/8" square cypress for both the inner and outer wales. Was going to do something similar to what I did on the pirogue last year with a solid outwale and a slotted style inwale and epoxy it all to the hull. Then I got to thinking, ( I know, I should quit thinking right? )
Number one thought is that the skinny pieces of wood are hard as all get out to seal up with epoxy and make them look nice and neat and I got to thinking about just putting several coats of linseed oil or some other type of oil like sealant and let them be at that and just replenish when needed. Is that a viable option? That's something I can experiment with a little and not the big question..... :shock:
Got to looking at the pirogue last night and it looks like the gunnels are getting more abuse than just about any other part of the boat. At some point on the pirogue those will have to be sanded down to get out all the gashes and chunks smoothed out and everything refinished again. Thinking about going with stainless or brass screws every 6 inches or so on this new build and solid inwales also. Would also seal everything up with some sort of clear caulking to keep water out from underneath them but when they get beat up to the point where they needed replacing, it would just be a matter of unscrewing everything and replacing. With the pirogue, someday I will be faced with epoxy glued railings that need replacing and no easy way to do it short of cutting them off the boat and re-installing.
Any ideas, thoughts?
Thanks as always!
Brad
Thanks as always!
Brad
