OK brain trust, here's the situation:  I'm building 2 UJ pirogues 15' 5" 3mm meranti with 6" butt blocks of 1/4" luan. 4 rib option.  Novice.  I had liked the pix of closet bar rails I had seen so I decided to go that route, but I thought I'd go one better and not split the bars with a rabbet instead I opted for a single bar with a 3/4' groove in the middle to lay right over the top.  It looks great.  I figure to cut the top 3/4" of the ribs to curve around the rail and epoxy thereto.  Now that I am ready to assemble, I am a little nervous about this.  Is this bar going to handle the torque?  Would it be better to add the rail first?  Certainly it would be easier to fit my adapted ribs that way and I could put bars across the ribs to strengthen until the boat was glassed.  Or am I going to have to steam those suckers and if I do, would epoxy stick to waterlogged pine?  WHAT SHOULD I DO? :?
