Thoughts on bottoms | SouthernPaddler.com
Thoughts on bottoms
john the pom
345
Queensland
:oops: Ok I could have phrased it better. Ron I understand you use what we call "underseal" that is the stuff put under cars etc to prevent rust, on the underside of your boats as a sacrificial layer. Will you use it on the current build? Do you apply it with a brush? What kind of thickness do you aim for? How do you rate it against the usual graphite epoxy mix? Does anyone else have any thoughts on this?
I also did a bit of thinking about using "plasti dip" http://www.plastidip.com/ but this could end up costing more than the rest of the boat. Anyone have any experience or comments to make about this product?
Cheers John.
