Chuck asked, and I'll try to show some of the pictures of what I am building. This is a work-in-progress, so check back as I add new photos.
I'm working off of a variation of Richard Frye's Yakoo (Kayak/Canoe), called the Stealth Yakoo. The basic form is a pirogue that is 12" high at the bow, sloping to 8" or so at the stern, and is 16' long from tip to tip, and 27" across at the widest point. It will be eventually decked so that it will be a either a decked canoe or a more opened kayak. I do not plan any Eskimo rolls with this boat!!!!
First, here is a picture of Richard Frye in a Yakoo Stealth, in cameo colors ... http://community.webshots.com/photo/958 ... 9142WbYcJN
To start with, you use the plans for the Cheap Canoe that you can get from Bateau boats. Cut out the sides and braces to spread the middle, and then stitch stems together -- like this: http://community.webshots.com/photo/958 ... 0964NKULQr
Add the bottom on and stitch, and you get this:
http://community.webshots.com/photo/958 ... 0652OBJJfY
I'll add some more photos later as I tape the seams and start to epoxy ...
