Power Yak by Glen-L (next Adventure) | SouthernPaddler.com
swampwood
276
Bayou State - Louisiana
Jack,
waterline with 500lbs. is suppose to be 3 1/2" at there design weight.
Hope to at least cut 30lbs. off the design. That would be shooting for 80lbs. finished.
Think it is possible? Give me you'lls suggestions. I am open "minded"!!!!!!!!
swampwood
276
This is the material list to build by design.
I see alot of opportunity to lighten the boat and still make it a good looking boat.
ITEM MATERIAL NO. PCs. SIZE
Breasthook Mahog 1 1" X 6" X 7"
Sheer Mahog 2 1"x5/8"x17' 6"
Deck beams #8 & #9 Sp or Mahog makes both 1"x51/2"x 32"
Deck beams #10, #11, & #12 Mahog makes all 1" x 5" x 32"
Carling Mahog 2 1" x11/4"x 13'
Aft end of cockpit beam Mahog 1 1" x 2" x 2'
Longi top cleat Mahog 2 1" x 1" x 9'
Aft deck strongback Sp 1 1"x 3/4"x 2'
Clamp at cockpit Sp 2 1/2"x 2 1/2"x 8'
Clamp at hatch Sp 2 1/2"x 2 1/2"x 4'
Clamp at #8 & #9 Sp makes both 1/2"x 3" x 3'
Cockpit coaming #18 Mahog makes both 1" x 6" x 8'
Spray shield Mahog makes both 1" x 5" x 30"
Hatch coaming/frame Mahog makes both 1"x 1 1/2"x 4'
Hatch beams Mahog makes both
Hatch battens Mahog makes both 1" x 3/4" x 7'
Seat ledge S-2 Mahog makes four 1" x 3" x 18"
Seat brackets #16 (B-2) Mahog makes eight 1" x 2" x 4'
swampwood
276
I do not plan to use any mahog, except spray shield.
I am thinking about using 4mm Marine instead of the 1/4.
Using 9mm & 12mm marine instead of most of the mahog.
Using cypress for the carlins, sheers and top strips instead of 1/4" plywood.
Glass outside with 6oz. and inside with 4oz cloth.
Hopefully I will be looking at 70-80lbs. when finished vs 110lbs.
Sounds good. I much prefer to glass inside for strength and resistance to splitting and rupture if the bottom gets up onto an obstacle. I've had much better luck with a loose weave glass than a tight weave.
WDfrmTN
seedtick said:
i like their caveat about not being able to make the boat shorter or longer and not changing the width
They obviously aren't in the real world
Actually, they are...the real world of sleazy lawyers and stupid litigation. For "amateur built" plans, CYA is the best way to go. Glen-L has been around a long, long, time.
swampwood
276
What does CYA mean :?:
swampwood
276
Received the plans today and started looking over them.
So far I see lots of ways to cut down on the weight without sacrificing strength.
Trying to figure out how to install the trolling motor and keep it higher than the bottom of the boat? They have it way below the bottom of the boat.
swampwood
276
My idea is to incorporate the motor into the hull.
Thinking of installing the motor in a tube (pvc pipe), even with the bottom or stightly below, and using kayak rudder to steer it. It would have a water pickup in the forward end of the tube.
I like the steath mood. The only way you would be able to tell it is motor powered is the hole coming out the back of the hull.
My question is will I work? :!:
