Using a Eagles Nest single hammock on the last trip I did run into a problem with there rain fly.
See. http://www.neilbank.com/phpBB2/viewtopic.php?t=5820
It worked but I had to have it set so low to the hammock I hit it everytime I got in or out of the hammock.
Thinking about things and no one said you can't use everything out there for your comfort.... SO.
Here are my thoughts.
The ENO is open and easy to get into and out of , just sit up and swing your feet to the ground. Now to make the system better for camping I have the following thoughts.
1. Set the hammock up.
2.Attach the skeeter screening and adjust it to fit the ends of the hammock ( where I want the hammock every time) and run a ridge lie to make this set up simpler. Especially since the bug netting needs a line to support it. So make it a part of the hammock when setting it up.
3. Forgetting the rain fly's that ENO offer's , I plan on getting one from Tom at Hennessey Hammocks like I have for the Safari Deluxe I have used in the past and trust for protection. It is 144 inches by 132 inches and offers a lot of coverage and can be hung independently from the hammock..or as a part of it.
4. Skip the Slap Straps and only use them as tree huggers since they restrict the distance and angle you can set the hammock up with.
5. By pass everything they tell you and get the system set up using ropes to hang the hammock with , have the bug netting tied off to the hammock at the desired length with a center line to determine the way the hammock sets up everytime.
6. Use the slap strips as tree huggers and have a main line attached to the Beiners at the ends of the ENO Hammock to tie off to the slap straps , The distance of the rope would be a personal choice. No matter what the distance is between trees. Then spread out the rain fly and tie it off.
To pack everything up use the Snake Skins when trying to adjust the hammock , Yep easy to use but really restrictive on the way you want the hammock. Then put the netting and hammock in as a complete unit and wrap the rain fly up with it , or if it is possible include the rain fly in with the netting and hammock.
Just some things I am working on to figure out how to make this outfit even simpler to put up and take down while offering a lot of comfort ... Yep , I really like the comfort and simplicity of the ENO Hammock.
It will offer a good nights sleep , no bugs with the bug netting and a dry place with a decent rain fly... Then if it is really simple to set up and take down , all the better.
I will do more on this in the back yard. Then anyone who wants to ... Take the information and customize it to your use like we do with our boats.
It's all jdupre' fault by giving me good ideas with his home made hammock. http://www.neilbank.com/phpBB2/viewtopic.php?t=5919
