I had intentions of making some patterns from cheap ply so the next build would simply be a matter of drawing out the lines onto the good ply or use them to make strip panels.  I should have just built the boat as I usually do because I have never built two boats the same.  Long story short. pattern was not correct and I built two sides that would not work.  The flimsy ply's butt splice moved or  itwas too stiff to show the proper curve.  A very good learning experience but a waste of time and work.
This boat's sides are 8" high and flair 30deg. at its widest point.  I found out because of the 5"+ arch needed to match the rocker I wanted, two 12" X 8' panels glued end to end to form a straight board will not work.  As I have done before  11" wide panels joined at the proper angle will work .  They will make a board that appears bent or shaped as a shallow v.
The angle is easy to determine.  I clamp in place one panel and then the other, overlapping where I want my splice to be.  Marked the end of the top panel on to the other. Removed the panels, and made the  splice at the angle indicated.  I did scarf joints so I had to allow for the extra length needed.
After the joint cures completely  I reattached the sides  and traced along  bottom edge of the floor and the stem pieces where they meet the sides.  Removed the sides and marked the top edge of the sides close to the shape I am looking for.  Their final shape will be made after the sides are attached and can be turned over.  I then cut out the outline but stayed proud of the lines .
