Hi Chad,
not sure if I have welcomed you aboard yet mate. (I have been away for a couple of weeks) but welcome aboard anyway.
Re the stems, I thought there was too much angle also. There isn't. It all comes together really nice once you put the sides together and then spread them with the frames. 45 degrees is fine but if you would like a little steeper stem that is also fine. It is your boat mate, build it the way you like it.
I am not sure what you mean but it is critical that the sides are identical in length and height. It is also very important that the sides are level with eachother when you stick the stem pieces and frames in place. (no twist)
Matt has some very good tips on how to achieve this in the tips and tricks section of his Jem Watercraft site here -
http://jemwatercraft.com/forum/viewforu ... eb77a83265
